Author Topic: 64-bit support  (Read 1010 times)
dashley
64-bit support
« on: January 29, 2010, 09:57:28 pm »
64-bit support.
Almost all my machines now support/run 64-bit operating systems. Seems a shame to clutter up the machine with 32-bit libraries just to run SlickEdit.
swsnyder
Re: 64-bit support
« Reply #1 on: July 13, 2010, 12:36:54 am »
Another vote for native 64-bit binaries in Linux.
That would avoid having to load an otherwise-unneeded set of 32-bit libraries, which would save system RAM and improve the start-up time of the editor.
Also, I want a pony.
jwdonahue
Re: 64-bit support
« Reply #2 on: July 28, 2010, 11:53:49 pm »
More Windows debugger support; ntsd/cdb should get the same support that gdb gets.
Definitely need a 64 bit version.
It would also be nice if I could have a single workspace with hundreds of projects and tens of thousands of files and still be able to load SlickEdit before lunch-time.
Boost build support!
dashley
Re: 64-bit support
« Reply #3 on: August 10, 2010, 06:05:29 pm »
64-bit support for x86_64 Linux is a must. 90% of the Linux machines we use run a 64-bit version of Linux.
