Author Topic: Wrap at beginning/end=On is not working  (Read 2830 times)
dfechser
« on: October 19, 2016, 05:49:29 pm »
I've always set the Editing:Search:"Wrap at beginning/end" to "On" and used it this way.
About two days ago this suddenly stopped working and now always prompts me when it reaches the end of the file.
I've tried the following:
1. Close and reopen SlickEdit.
2. Change the option to "prompt", then "off", then "on". I closed and reopened SlickEdit each time.
3. Restart my PC.
Is there something that may have changed in my options or installtion that is affecting this option setting?
Thank you,
DaveF
Re: Wrap at beginning/end=On is not working
« Reply #1 on: October 19, 2016, 06:08:50 pm »
If you are using gui-find, either the Mini-Find or Find and Replace tool window, it uses whatever setting was last used in the dialog.  Changing the option in  Tools > Options > Editing > Search does not automatically force a change in the dialog setting unfortunately.
dfechser
« Reply #2 on: October 19, 2016, 06:45:47 pm »
Thanks!
I wasn't aware of that and didn't set it intentionally. Clearing that fixed my issue.
I'm good now.
