Author Topic: Running under Windows Vista B2  (Read 7072 times)
DrATEasy
« on: July 18, 2006, 04:29:07 pm »
Looks like SlickEdit have a problem with the new Users folder that replaces Documents and Settings. I keep on getting "Could not create tags database c:\documents and Settings\Ronniey\My Documents\My SlickEdit Config\10.0.3\tagfiles\cpp.vtg". I tried to change the security for the folder or run as admin but does not seem to work.  If you place the path and try to open the vtg file with notepad it works (since vista have hidden shortcut to allow you access the old folder names) but slickedit can not open it for some reason.
I'm using Slick Edit 10.0.03
Thanks
Ron
