Author Topic: crash in windows 21.0.0.12  (Read 3293 times)
  • Hero Points: 119
« on: October 31, 2016, 08:38:23 pm »
I got a crash in 21.0.0.12.
I tried uploading the crash dump file to support.slickedit.com, but it keeps telling me "MOVE UPLOADED FILE FAILED!". The 7zipped file is 100MBytes. I will try sending again.
  • Hero Points: 119
Re: crash in windows 21.0.0.12
« Reply #1 on: October 31, 2016, 08:40:24 pm »
It keeps failing to upload to support.slickedit.com. I tried using case number "14420", and still got an error that "MOVE UPLOADED FILE FAILED!". Please give me another way to upload. Email will not work because the file is 100MByte even after 7zipped.
SlickEdit Support
  • Hero Points: 26
« Reply #2 on: November 01, 2016, 12:41:24 pm »
Looking into this now. We'll let you know when you can upload.
SlickEdit Support
  • Hero Points: 119
« Reply #3 on: November 07, 2016, 04:07:24 pm »
Hi:
I sent the crashdump file to SE support separately.
Any progress on this issue?
Is it the same crash I reported for Linux in 21.0.0.12?
Rob
SlickEdit Support
  • Hero Points: 26
« Reply #4 on: November 07, 2016, 04:11:11 pm »
We'll check with Dev to see where we are on this.
SlickEdit Support
  • Hero Points: 119
« Reply #5 on: November 15, 2016, 06:43:57 pm »
Just got another crash. Is it same as last one? Is root cause known?
New crashdump can be downloaded from my google drive here:
https://drive.google.com/open?id=0B7AlniF_4GyYNFpZaXl2ZmxzbVk
SlickEdit Support
  • Hero Points: 26
« Reply #6 on: November 15, 2016, 08:02:37 pm »
What exactly were you in the middle of doing when this one happened?
SlickEdit Support
  • Hero Points: 119
« Reply #7 on: November 15, 2016, 08:09:15 pm »
I don't recall exactly. I think I pressed "Ctrl+." to find the definition of something.
I had a 2nd crash today where I did not even hit "Ctrl+.", I was using arrow keys to navigate the same file that crashed before.
After 2nd crash, I retagged my workspace. Has not crashed again, but I haven't used it much though.
  • Hero Points: 446
« Reply #8 on: November 17, 2016, 01:58:19 am »
I checked out this crash dump, it looks like it is the same as a problem we have already fixed for 21.0.1.
