Author Topic: Save history for Run/Debug program arguments  (Read 952 times)
LouieM
« on: August 07, 2010, 05:26:25 pm »
A lot of the programs use the command line for processing various files with various options.  It would be nice if under the 'GNU C Options|Run/Debug|Program Arguments' the text entry box for the program arguments was a drop-down combobox that kept a history of the arguments you have set for the program.  I have to keep this history in a paper notebook, and type it in every time I want to test different parameters.  On that same dialog box, please fix the dialog sizer so that size of the edit box changes with the size of the dialog box, (and remember the last size of the dialog box).  That way we can see the entire command line without scrolling.
