Author Topic: #define tracing, ability to show what a macro would expand to  (Read 1087 times)
MikeDavies
« on: August 11, 2010, 09:01:30 am »
#define tracing:  it should be possible to select a #define'd symbol and cause it to be expanded completely to it final value as the compiler would.  This should take into account compile time constants defined in make etc.
Mike
volovyan
Re: #define tracing, ability to show what a macro would expand to
« Reply #1 on: September 19, 2014, 09:23:39 pm »
C/C++ macro expansion support with ability to show expansion steps. Especially useful if ## are used in the macro.
If I am not mistaken, currently only Eclipse supports this.
jwiede
  • Hero Points: 12
« Reply #2 on: December 08, 2014, 10:22:48 pm »
+1 to this suggestion -- it would be nice if SE could serve as a "C/C++ macro previewer/debugger" showing the expansion steps, indicating the step where expansion fails (when it does), etc.
jwiede
  • Hero Points: 12
« Reply #3 on: August 21, 2017, 02:31:42 am »
Mike
Another excellent request, any hope we'll see something like the above in V22?
