Author Topic: Debugging of ARM processors / jLink  (Read 3044 times)
jorick
  • Hero Points: 17
« on: March 07, 2011, 03:54:03 pm »
A plugin to allow debugging of ARM processors via Segger's jLink.
SidInNJ
Re: Debugging of ARM processors / jLink
« Reply #1 on: November 16, 2020, 02:56:30 pm »
Yes Please!
In my case, I need to use a Win10 environment. In the meantime (before SlickEdit directly supports the Segger J-Link), I've seen posts about how people are using J-Link with SlickEdit, but primarily in a Linux environment, and without showing how they configured SlickEdit to work. It would be great to see a sample Win10 configuration for J-Link support.
Thanks!
Sid
  • Hero Points: 292
« Reply #2 on: November 16, 2020, 03:28:03 pm »
I think launching JLinkGDBServer(CL).exe and using SE gdb (remote) debugging should work.
There is basically no difference between Linux/Windows platform.
ebbe
« Reply #3 on: November 16, 2020, 07:14:06 pm »
It does work. I have used a Segger in this way and it worked beautifully.
SidInNJ
« Reply #4 on: November 16, 2020, 09:48:34 pm »
Hi Ebbe,
Any chance you could post your configuration for the interface to the JLinkGDBServerCL? I'm missing something.
ebbe
« Reply #5 on: November 17, 2020, 05:39:16 am »
Sorry, it was about four or five years ago on a PC that I no longer have. And I don't even have ready access to the Segger JLink right now so I can't throw an experiment together either.
But let's work with it here. I may be able to drag something out of my memory if you describe the problems, you are having in more detail.
SidInNJ
« Reply #6 on: November 17, 2020, 03:41:53 pm »
Thanks for the offer to help! Here are some things I tried (more interesting may be toward the end):
Debug, Attach Debugger, Attach to Remote Process (GDB).
Connect via socket
Host: localhost
Port: 8000
GDB configuration:
Command line options
-select USB -device Cortex-M4 -endian little -port 8000 -swoport 8001 -telnetport 8002 -if SWD -speed 4000 -noir -LocalhostOnly
vsdebugio connection port: 8000 (Options, Debugging, General, vsdebugio connection port:)
Use remote proxy: Off
Use Extended Remote mode (not checked)
This usually ended up with the debug display showing and "Starting debugger..." at the lower left, but SlickEdit hung
until using Task Manager I killed the JjLinkGDBServerCL.exe(32 bit) task under SlickEdit.
SlickEdit would then say: "Error starting debugger: GDB has terminated prematurely".
============I also tried:
Port: 2331
GDB configuration:
-select USB -device Cortex-M4 -endian little -port 2331 -swoport 2332 -telnetport 2333 -if SWD -speed 4000 -noir -LocalhostOnly
vsdebugio connection port: 2331 (I also tried port 2332)
If I was more patient, after about 3 minutes, SlickEdit would say: "Error starting debugger: DGB returned an error
opening the executable. "Reply did not begin with '^'".
If I started it via Debug, Start Debug: SE would say "Error starting debugger: GDB has terminated prematurely".
============= If I started it via: Build, Debug:
SE would download the file to the board (via a COM port), start JjLinkGDBServerCL.exe, but JjLinkGDBServerCL would end with :
  Listening on TCP/IP port 2331
  Connecting to target...
  Connected to target
  Waiting for GDB connection...
If I set the ports back to 8001,8002,8003:
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V11 compiled Nov  2 2020 09:15:32
Hardware: V11.00
S/N: 51006547
Feature(s): GDB
Checking target voltage...
Target voltage: 3.35 V
Listening on TCP/IP port 8000
Connected to target
Hopefully your memory of four years ago is better than mine for last week!  :)
