Author Topic: Make the project name available in C/C++ Aliases  (Read 1449 times)
garion911
  • Hero Points: 13
« on: September 08, 2011, 04:09:15 pm »
  • When you right click on a project in the Projects Tool Window, that you can add a new file from a template.
  • Make the project name available in C/C++ Aliases
My goal is to add a header to my C/C++ files that works with doxygen, and one of the 'requirements' is to have the project name in there. I've been using aliases for a while to add the basic structure, but can't find a way for it to insert the project name.. I tried the %RM (and %\rm) I've seen elsewhere, but I think cause aliases use %\r for the return type, its not working.
I think I could do it with file templates, but since they are buried in a menu, and not where I generally right click to add files, I don't use that feature... I think I could figure out how to add it to the menu, but I think it should be there from the get-go...
  • Hero Points: 291
Re: Make the project name available in C/C++ Aliases
« Reply #1 on: September 08, 2011, 04:39:56 pm »
@garion911: You can easily extend aliases by using the 'execute macro' feature '%\m':
- add this to e.g. common aliases 'alias.slk'
%\m_alias_ins_project%
and this alias helper macro to your user macros:
void _alias_ins_project()
   _insert_text( strip_filename( _project_name, 'PDE' ) );
You see - there is no limit ;)
Have fun,
« Last Edit: September 08, 2011, 04:42:23 pm by hs2 »
