Author Topic: SlickEdit 2016 x64 21.0.0 has copy-insert issue  (Read 1256 times)
acmemike
« on: November 08, 2016, 01:24:45 pm »
SlickEdit 2016 x64 21.0.0 has serious copy-insert issue between edit buffers.  Intermittently the insert will do nothing.  If I create a new empty file I can insert my selection to that file.  Then I can go back to the file I want to insert to and the operation works.  This plus the fact default UI changed is sending me back to v 20.0.3.0.  I dont see any more SE upgrades in my future, too many wasted cycles on issues like these.
  • Hero Points: 137
Re: SlickEdit 2016 x64 21.0.0 has copy-insert issue
« Reply #1 on: November 08, 2016, 01:51:42 pm »
What emulation are you using?
acmemike
« Reply #2 on: November 17, 2016, 12:41:06 pm »
sorry for long delay, using Brief emulation.  It may be related to using SE via remote desktop, its definitely intermittent.  Thanks.
