Author Topic: Please fix the Not in first column on startup bug  (Read 2069 times)
larry1301
« on: October 03, 2014, 05:37:04 PM »
Please fix the "Not in first column on entry" problem as described in this thread.
http://community.slickedit.com/index.php/topic,9891.0.html
I just opened SE. SE opened 8 files from my last session. 4 files had the cursor in the first column and the forsti visible column was column 1. The other four had the cursor in the first visible column. Unfortunately, the first visible column range from column 15 to 74.
« Last Edit: October 03, 2014, 05:40:52 PM by larry1301 »
