Author Topic: Ability to preview files from Project/Open/Files tool window  (Read 2326 times)
PurdueEEGrad
  • Hero Points: -17
As a loyal user of SE over the years - I have many, many small test files in SE
code.
Almost all are NOT in an SE project or workspace - and I often need to review a
directory - of small test files quickly (see attached).
In Windows Explorer (the OS Shell) - you can preview *.txt files (see attached).
It would be great to have a *.e file previewer for SE code files - so I can
quickly review code that I haven't touched in months or years.  This saves a lot
of programming time by finding the file that I need quickly - opening it - and
getting the code I need ASAP.
Slickedit is a stellar product - due to feature extension via user *.e files.
This product feature would help the Slickedit community - to walk through small
code examples and test cases quickly - by just using the up/down cursor keys -
in the Windows Explorer.
