Author Topic: Add more options to Sort Lines.  (Read 1583 times)
JimmieC
  • Hero Points: 16
« on: February 06, 2015, 09:33:31 pm »
Add more options to Sort Lines. Such as, Alphanumeric, Date, IP Address, Line Length, etc.
Also, add option to select which column sort starts from. Sometimes the sort data is not a column 1.
See Boxer editor for reference.
Unlike Boxer, add options for what the input date format is including ISO 8601. Or, mm-dd-yyyy, dd-mm-yyyy, d-mm-yy, etc.
dfechser
Re: Add more options to Sort Lines.
« Reply #1 on: March 11, 2015, 07:05:36 pm »
I would like a hot-key for sorting.
