Author Topic: Resize auto-list-members dialog  (Read 538 times)
  • Hero Points: 116
« on: February 26, 2015, 02:15:53 pm »
In C code, if I have a variable that is a struct, and I type the dot '.' character, I get a list of the members of the struct, and then can use up/down arrow to choose.
The window that shows the members of the struct is very small. If this window could be made larger, it would be very helpful.
  • Hero Points: 320
Re: Resize auto-list-members dialog
« Reply #1 on: February 26, 2015, 03:40:30 pm »
You can drag the bottom of the window down.  The width is re-sized automatically.
