Author Topic: [SOLVED] Default native support for .txt file types.  (Read 1645 times)
JimmieC
  • Hero Points: 17
« on: March 08, 2015, 04:44:15 PM »
Default native support for .txt file types. File New does not provide .txt as a file type option in (v2011 anyway). Default tabs, etc. could be applied to that file type.
« Last Edit: November 22, 2016, 12:49:18 AM by Dennis »
mwb1100
  • Hero Points: 13
Re: Default native support for .txt file types.
« Reply #1 on: March 09, 2015, 04:20:29 PM »
It's in the list as "Plain Text".  I agree that it should simply be named "Text" because that's what I look for.
JimmieC
  • Hero Points: 17
« Reply #2 on: March 09, 2015, 04:50:32 PM »
OK, I see it. Thanks. I was looking for "Text" as you surmised.
