Author Topic: highlight or color code unused definitions, e.g. dead code  (Read 613 times)
rgloden
  • Hero Points: 5
It would be cool if there were a way to uniquely highlight or color code unused definitions, e.g. dead code.  Currently from SE you can go through the suspect definitions and do a show references looking for dead code.  I have other tools which can generate a list of unused objects / types but displaying in a visual context would be so much better.
Ok you macro writers, I sure this would be easy for you guys.
