Author Topic: Easier way to open files in project/workspace  (Read 2440 times)
deuse
« on: July 01, 2015, 01:17:49 PM »
I suggest a solution for the following issue:
Usually in a project (and/or workspace) you have a lot of source files, which often are organized in subfolders (e.g. Controls, OwnLists, Printing...). Very often you have to open a special file, and for doing this you can
- use the Projects window: Problem: you always have to expand/collapse branches for the subfolders. The +/- buttons in the tree list are very small and you have to concentrate for positioning the mouse. Yes, that's a problem: you are already concentrated on your work, and every distraction sucks.
- use the files window: That's welcome, but there you only see your already open files.
Great would be a window, where all your project / workspace source files are listed in rows and columns (kind of grid). Switching between
a) grouped alphabetically within subfolders and
b) alphabetically showing all files regardless of subfolders
Of course this window should be sizable, position and size are reminded and it should be possible to position this window on a second screen. Also, selecting (and opening) should be possible using a) the mouse and b) the keyboard.
Maybe you could enhance the files window for that.
  • Hero Points: 292
Re: Easier way to open files in project/workspace
« Reply #1 on: July 01, 2015, 03:08:18 PM »
@deuse: Concerning open project related files you're aware of 'Project>Open Files from Project' resp. '..Workspace' ? Just to be sure. There is more than just the 'Files' ;)
deuse
« Reply #2 on: July 01, 2015, 03:34:34 PM »
Thanks. I re-found that, but only after I posted... I forgot about that...
But a kind of grid view (file names only, maybe full path displaying as a tooltip on mouse-hover) would improve the file dialog further.
