Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Slick-C® Macro Programming
comparing 2 settings of the same SlickEdit version
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: comparing 2 settings of the same SlickEdit version (Read 4010 times)
mguttman
Junior Community Member
Hero Points: 1
on:
November 22, 2016, 02:43:27 PM »
Hi,
Is it possible to configure the .slickedit repository that SlickEdit uses?
I want to open 2 instances of the same SlickEdit version and compare different macros and settings.
Maya
Logged
SlickEdit Team Member
Senior Community Member
Hero Points: 151
Re: comparing 2 settings of the same SlickEdit version
Reply #1 on:
November 22, 2016, 02:53:19 PM »
On the command line you can use the "-sc" flag to specify the configuration directory to use:
Code:
[Select]
/opt/se21/bin/vs +new -sc /tmp/testconfig
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
