Author Topic: Class tool window finds super class in wrong language  (Read 3244 times)
jbhurst
  • Hero Points: 33
« on: May 03, 2007, 02:18:35 am »
Hi,
I have tagged my Ruby runtime libraries in the "Ruby" Tag Files category in the Tag Files dialog. I created a Java project with unit tests, and forgot to add junit.jar to the tag file for the workspace. In the Class tool window, I get my Java test class having a Ruby base class! See attached shot. (I don't have any Ruby files in this workspace, honest.)
I don't think it's a problem with tagging generally, since trying push-tag on the TestCase in the file correctly reports "Tag 'TestCase' not found." Seems like just the Class tool window is getting a little confused.
Comments?
John Hurst
Wellington, New Zealand
Ryan
  • Hero Points: 77
Re: Class tool window finds super class in wrong language
« Reply #1 on: May 03, 2007, 01:54:30 pm »
Hi John,
What happens when you do have junit.jar tagged with this particular example?
- Ryan
jbhurst
  • Hero Points: 33
« Reply #2 on: May 03, 2007, 07:35:36 pm »
Ryan,
I should have said: it works fine with junit.jar tagged.
Thanks
John Hurst
