Author Topic: "Open Folder" as in Visual Studio Code  (Read 1611 times)
schugh
« on: December 14, 2016, 05:43:26 pm »
Is there a way to "open folder" similar to what you can do in Visual Studio Code?
Where it just shows all the subfolders and the files within?
And I don't mean the folder tool window in Slickedit.
The "open folder" option in Visual Studio code is very handy at certain times and fast as it's similar to a project view.
  • Hero Points: 446
Re: "Open Folder" as in Visual Studio Code
« Reply #1 on: December 14, 2016, 09:17:28 pm »
I'm not familiar with visual studio open folder. It's sound like directory view in the Project tool window. In custom view you can do an add tree and set the options for creating folders for each directory. This takes more steps to set up but provides more configurability than directory view.
