Author Topic: The FIND dialog  (Read 1269 times)
  • Hero Points: 185
The FIND dialog
« on: February 23, 2017, 12:26:11 am »
In FIND, I wish that there were two buttons, "Find" and "Find all".
Also remove the "List all occurrences" checkbox.
I frequently switch between find and findall - having two distinct buttons would be a lot better than this checkbox.
This would also be more consistent with Replace: It has "Replace" and "Replace all", and does *not* have a "Replace all occurrences" checkbox.
