Author Topic: Real-time spell check  (Read 2294 times)
rh
  • Hero Points: 6
« on: April 04, 2017, 03:35:58 am »
Notepad++ does a nice job of it.
  • Hero Points: 135
Re: Real-time spell check
« Reply #1 on: April 04, 2017, 05:30:52 pm »
Can you elaborate what they do that you might like to see in SlickEdit?
rh
  • Hero Points: 6
« Reply #2 on: April 04, 2017, 11:47:19 pm »
Like in Word/Outlook, they just underscore words with the red squiggly line.  Nothing I did to enable that either.  Looks like they only look at quoted strings and comments, which is all I need.  Right click on an underlined word and they popup suggestions.
Also nice that I don't have to remember to check spelling - actually invoke something.  Just keep watch for the red underscores - which I'm used to doing since VS does that for code that isn't correct.
« Last Edit: April 04, 2017, 11:52:35 pm by rh »
  • Hero Points: 135
« Reply #3 on: April 05, 2017, 07:47:38 pm »
Do you have it turned on?
To turn it on for a single document, go to Document>Spell Check While Typing.
To turn it on for an entire language, open a file of that language, and then to go Document>(language) Options, and in the Options dialog turn on "Spell check while typing".
rh
  • Hero Points: 6
« Reply #4 on: April 08, 2017, 12:23:13 am »
Ok.  So I did look - under Tools - then made the ASSumption that was all there was.
Feature complete!  I've now turned it on for ALL languages.  Works beautifully THANKS!
  • Hero Points: 135
« Reply #5 on: April 08, 2017, 02:13:47 am »
If you go to Tools>Options there is a search box.  For property sheets, it will highlight found items, so it doesn't make it as obvious here, but you will know it that what you searched for is somewhere on the tab.
