Author Topic: Ability to close a project within a workspace  (Read 2895 times)
JimmieC
  • Hero Points: 17
« on: April 06, 2017, 09:14:27 PM »
I have a workspace with 3 projects in it. The code base is similar for variants on the target hardware. When I use Go To Definition or Find References, it gives me choices for the whole workspace, not just the active project (or potentially open projects). Eclipse allows the user to close projects that they are not currently interested in which removes them from various searches, etc.
Jim
  • Hero Points: 153
Re: Ability to close a project within a workspace
« Reply #1 on: April 07, 2017, 12:08:09 AM »
What happens if you go to Project>Properties, and on the Files tab change the combo box at the bottom to "Tag files with project-specific tag file"?  You'll need to do it for each project.
  • Hero Points: 530
« Reply #2 on: April 07, 2017, 11:43:54 PM »
You could create workspaces which have different project sets in them. Then switch workspaces.
