Author Topic: HTML Control usage  (Read 5264 times)
ravi.shiva
HTML Control usage
« on: July 20, 2006, 04:45:11 am »
Hi,
I am writing macro to show a form in the Editor. In the form I want to display a HTML file. How can I do that?
Should I use HTML Control or is there any other way?
Ravi Shivashankaran
  • Hero Points: 480
Re: HTML Control usage
« Reply #1 on: July 20, 2006, 05:11:04 pm »
The HTML control should work fine, but keep in mind that it only supports a limited subset of HTML.  The major items that it does not support include tables, scripts, applets, forms, and frames.  It's handling of images is limited to bitmaps.
