Author Topic: Diff button, along with Yes/No/Cancel, in File:Revert dialog box  (Read 1042 times)
eitheta
Obviously not a critical need, but might save a few mouse-clicks on occasion.
  • Hero Points: 135
Re: Diff button, along with Yes/No/Cancel, in File:Revert dialog box
« Reply #1 on: June 21, 2017, 06:55:10 pm »
I'll make a note of that.
There is a command you can run, "diff-current-file".  If you type that on the SlickEdit command line, it will diff the current buffer with the file on disk.  You could also bind that to a key.
