Author Topic: Find Symbol - Exact  (Read 1260 times)
  • Hero Points: 182
Find Symbol - Exact
« on: June 22, 2017, 11:46:43 pm »
In FindSymbol the default is prefix matching.
So, if I type "max" in SearchFor, it finds tons of stuff from lots of system headers.
If I really only want to find max, as in a function called "max()", or a macro called max, it is a pain.
I can turn on RE matching and type "^max$", but I'm just too lazy - and that makes the matching *much* slower.
I assume that when "Match substring" is off, then the results should be the same as matching with RE and prefixing with ^, right?
Exact matching doesn't even need to have a checkbox, just sort the results differently --- put exact matches first.
  • Hero Points: 434
Re: Find Symbol - Exact
« Reply #1 on: June 23, 2017, 07:58:49 pm »
Try "::max" to restrict the search to instances outside of classes.  Then the exact matches should be at the top of the list (unless you have substring or regex enabled).
  • Hero Points: 182
« Reply #2 on: June 23, 2017, 08:36:16 pm »
That doesn't work -- FindSymbol, AFAIK, has never allowed names to include namespace or class names as part of the symbol.
Any string with "::", ".", "/" separators always returns no results.
  • Hero Points: 434
« Reply #3 on: June 23, 2017, 09:26:15 pm »
It does if you have "Look in:" set to "<Use Context Tagging(R)>", which uses the current document to determine the scope of the symbol search.
I was also assuming you were in C++.
  • Hero Points: 182
« Reply #4 on: June 23, 2017, 09:53:36 pm »
Interesting, I've never been able to make much sense of LookIn: Its really confusing (due to the available options, and the behaviors of those options, lack of documentation, and whatever else its behavior is conditional upon).
While exactly "::max" works as you say, "::" in general does *not* work correctly (or at least not reasonably).
When set to "Use context tagging":
"LocalMaxProfile::max" --> Matches things C:\Program Files/Reference Assemblies/Microsoft/Framework/v3.0/PresentationCore.dll"
"LocalMaxProfile.max" --> Same
"LocalMaxProfile/max" --> Matches global scope things in various *.cpp and *.h files.
                    Change "LocalMaxProfile" to anything non-empty string and the results are the same.
Given that is it "Context tagging", why does it ever match anything that isn't C/C++ when I'm looking up C++ stuff? (My project type is Other C/C++)
Why do I feel confused?
Please try those examples, as well as
    ::max
    /max
    .max
How does this behavior make sense?
Also, why then doesn't it work when LookIn is set to "c/c++"?
