Author Topic: project_load (workspace file list) empty  (Read 2429 times)
jnairb
  • Hero Points: 11
« on: August 02, 2017, 04:35:31 pm »
With beta 1 on Windows 7 x64, the first time I open the workspace file list (project_load command), the list is empty. If I close it and re-open, then it shows my workspace files. If I open the buffer list (list_buffers), then close that, then try project_load again, I again get an empty list (and closing and retrying works as before).
Re: project_load (workspace file list) empty
« Reply #1 on: August 02, 2017, 05:37:43 pm »
I looked into that after Beta 1 was released, noticed it during testing.  It will be fixed for next drop.
