Author Topic: list-tags dialog  (Read 2559 times)
jnairb
  • Hero Points: 11
list-tags dialog
« on: August 02, 2017, 06:34:12 pm »
Running beta 1 on Windows 7 x64. When I run list-tags, the "Class" column is empty and the class name appears under a column just titled "4".
Also, while trying to figure out why some tags had different icons next to them, I noticed that there's no pop-up text anymore when I hover the mouse over the icon(s) in the list-tags dialog.
(The extra icon "decoration" turned out to be on a couple of static functions. Still not sure what the little icon is supposed to represent -- it looked like a small lightning bolt?)
  • Hero Points: 485
Re: list-tags dialog
« Reply #1 on: August 03, 2017, 02:23:50 am »
Column problem easily reproduced. Thanks
  • Hero Points: 481
« Reply #2 on: August 03, 2017, 02:25:37 pm »
The lightning decoration represents static.  There is also a "T" decoration to represent templates.
I'll look into the icon hover problem.  I noticed that too.
  • Hero Points: 481
« Reply #3 on: August 03, 2017, 11:46:51 pm »
Quick update:  Both problems will be fixed in the next beta.
