Author Topic: Import options from VS2013 v18.0.1.2 64-bit failing  (Read 4004 times)
hebsahid
« on: August 03, 2017, 05:38:56 PM »
I installed the beta version and tried to import my current options I use on SlickEdit v18.0.1.2 64-bit and the process stop and fails with the following windows/stack.
Dialog Title: Importing options...
Dialog text Importing Tcl > General...
(a progress bar stopped)
Dialog Title: Click-C Error
Dialog Text: Invalid Argument file=OptionsXMLParser.ex offset=16154
[stack first lines]
 Invalid argument
OptionsXMLParser.ex 16154 se.options.OptionsXMLParser.retrieveSelectChoices(
   1:   ._typename()=se.options.OptionsXMLParser
   1:   .m-xmlHandle=11
   1:   .m-xmlFile=options.xml
   1:   .m-defaultFile=0
   1:   .m-templates:[language_setup_auto-complete]=<empty>
   1:   .m-templates:[language_setup_view]=<empty>
   1:   .m-templates:[_language_setup_beautifier]=<empty>
   1:   .m-templates:[lexer_editor]._typename()=se.options.DialogExporter
   1:   .m-templates:[lexer_editor].m-caption=
   1:   .m-templates:[lexer_editor].m-panelHelp=Color Coding is a feature that displays various portions of code in color for
Note: I have distributed those options successfully to other team members on the same version I have.
After I closed all those windows, SlickEdit did not load my options (expected) but start to send dialog boxes
Dialog Title: SlickEdit Pro
Dialog Text: Color coding profile 'cpp': Invalid type 'dqbackslash'
text between ' ' changes, but opens one after other and is impossible to work   :'(
I can share my current options if useful, let me know where to upload files.
  • Hero Points: 530
Re: Import options from VS2013 v18.0.1.2 64-bit failing
« Reply #1 on: August 04, 2017, 12:45:01 AM »
Please post your .zip file.  Thanks
hebsahid
« Reply #2 on: August 04, 2017, 01:33:32 PM »
Here is my file
hebsahid
« Reply #3 on: August 04, 2017, 01:37:17 PM »
Here is the stack failure in case somebody is interested, and some images of the failure.
dialogs is an example of what I see one after other when trying to work, after import options failed...
  • Hero Points: 530
« Reply #4 on: August 04, 2017, 01:55:05 PM »
Reproduced. Working on it.
  • Hero Points: 530
« Reply #5 on: August 04, 2017, 02:33:55 PM »
This is fixed for beta 2. The XML Wrap options won't import (you'll see errors in the message list) but there won't be any Slick-C stacks.
