Author Topic: [Fixed in Beta 2] Tabs Style ?  (Read 3278 times)
jmfrouin
« on: August 04, 2017, 03:59:03 pm »
Hi,
Under mac, I use SE 2016 and my tabs are like screenshot 1
But under SE 2017 they are like screenshot 2
I cannot find where to "tweaks" them to be like under SE 2016
Anyone have a clue ?
Thanks
PS: In fact it's all "Headers" which are larger :(
Screenshot 3 & 4
« Last Edit: August 12, 2017, 08:27:08 am by jmfrouin »
Rodney
  • Hero Points: 49
Re: Tabs Style ?
« Reply #1 on: August 04, 2017, 06:13:29 pm »
We are trying to figure out how to reproduce this here.
Which version of macos are you on?
Is your display scaled (some resolution other than default)?
I wonder if you are missing the font we are trying to use for Document Tabs (Options>Appearance>Fonts, Document Tabs). Have you tried picking a different font for Document Tabs?
Finally, please start SlickEdit with a clean config using the -sc switch pointing to a non-existent directory. Does the problem reproduce?
++rodney
jmfrouin
Re: Tabs Style ?
« Reply #2 on: August 04, 2017, 06:19:32 pm »
OK so :
Mac OSX 10.12.6
My resolution is "More space" (Screenshots)
I change the font for a non missing font (Screenshots)
And if I use the -sc flag to use default config I have the same problem (Screenshot)
« Last Edit: August 04, 2017, 06:22:27 pm by jmfrouin »
jmfrouin
Re: Tabs Style ?
« Reply #3 on: August 04, 2017, 06:26:59 pm »
Don't know if it help, but if I use the 72px size, tabs change there size (screenshot)
But if I change the font size for 9px, it stay too big in height.
Finally I have the same configuration (OSx, Resolution, Font settings) in both SE 2016 and SE 2017.
But display is not the same.
jmfrouin
Re: Tabs Style ?
« Reply #4 on: August 04, 2017, 06:39:37 pm »
And, I think, there is another bug on the "separator" betwen source code and associated header.
Under 2017 it is like screenshot 1, and under 2016 like screenshot 2
I really prefer the 2016's edition :)
  • Hero Points: 447
Re: Tabs Style ?
« Reply #5 on: August 04, 2017, 09:03:48 pm »
What font and font size are you using?
Tools > Options > Appearance > Fonts > Dialog, Document Tabs
jmfrouin
Re: Tabs Style ?
« Reply #6 on: August 05, 2017, 05:47:55 am »
Menlo, 11
SlickEdit Support
  • Hero Points: 26
Re: Tabs Style ?
« Reply #7 on: August 08, 2017, 03:16:08 pm »
We replicated this and will look into it for you.
SlickEdit Support
jmfrouin
Re: Tabs Style ?
« Reply #8 on: August 08, 2017, 07:27:16 pm »
Nice ! Thanks a lot !
Rodney
  • Hero Points: 49
Re: Tabs Style ?
« Reply #9 on: August 09, 2017, 10:28:14 pm »
Both issues (too tall tabs/titlebar, combined tabs) are fixed in the next beta (TBA).
++rodney
jmfrouin
Re: [Fixed in Beta 2] Tabs Style ?
« Reply #10 on: August 12, 2017, 08:27:24 am »
Small post to confirm it's fixed in Beta 2!
