Author Topic: list-tags fails to go to last function  (Read 2253 times)
jnairb
  • Hero Points: 11
« on: August 04, 2017, 07:51:57 pm »
If I bring up the list-tags dialog, select the name of the last function in the file, and press Enter, the dialog goes away, but the cursor position is not changed. Running beta 1, Windows 7 x64. Seems to be consistently recreatable for any .C file I have open.
  • Hero Points: 497
Re: list-tags fails to go to last function
« Reply #1 on: August 04, 2017, 09:14:35 pm »
Reproduced.  Will fix for beta2.
