Author Topic: Incorrect SE22-B1 perl color coding  (Read 788 times)
tuchman
  • Hero Points: 7
« on: August 06, 2017, 12:43:51 pm »
Win64, SE22-B1
Perl code coloring below incorrect (se2017.jpg)
Correct SE21 as reference  (se2016.jpg)
BTW: SE22 raised dialog on first startup: "Color coding profile: perl: Invalid type 'bqbackslash'".
This was repeatable on following starts.
I then went into "Languages|...perl|Color Coding", and clicked "reset".
The dialog is no longer raised.
Edit: Another example of SE22 color coding issues attached.
Thx!
« Last Edit: August 07, 2017, 03:52:53 am by tuchman »
  • Hero Points: 417
Re: Incorrect SE22-B1 perl color coding
« Reply #1 on: August 07, 2017, 03:54:19 pm »
We fixed the issue with "bqbackslash". Ran into same problem with other languages.
Reproduced the color coding issues. Fixed color coding issues for beta 2.
Thanks for posting.
