Author Topic: Dragging and docking toolbars  (Read 1596 times)
  • Hero Points: 192
« on: August 09, 2017, 06:42:48 pm »
When you drag a toolbar around slick will automatically snap it into specific locations - and previews this by rearranging the Slick UI to show where it would go if you drop it.
However, there is no way to override this -- say I want the toolbar to float near the top of the Slick window, I can't do that because Slick will autodock it there.
During drag Slick should force float the toolbar if you hold CTRL key while dragging - just like it does for tool windows.
  • Hero Points: 192
Re: Dragging and docking toolbars
« Reply #1 on: August 09, 2017, 06:46:32 pm »
Also, ESC should cancel the drag and restore the toolbar to its original location.
ESC should also work for Toolwindows - but currently ESC drops them where they currently are.
  • Hero Points: 461
« Reply #2 on: August 09, 2017, 08:34:16 pm »
In Options > Appearance > Toolbars, you can turn off "Allow Docking" for a specific toolbar.
