Author Topic: File -> New request  (Read 1920 times)
  • Hero Points: 189
File -> New request
« on: August 10, 2017, 05:32:51 pm »
It sure would be nice to be able to type a full path + filename into a single edit box.
Its very unnatural for me to have the filename first, then the path in separate boxes.
Instead of popping
SlickEdit Pro
Filename must not contain a path
OK
Just auto-fix it.
  • Hero Points: 448
Re: File -> New request
« Reply #1 on: August 12, 2017, 08:34:40 pm »
I definitely understand.
It's a bit of a UI problem. It looks nicer to separate the path from the name. Even if the Filename was really long, it still doesn't seem as user friendly and clean to put them together.
Try loading this tweaked beta2 workspace.e. It's missing completion for the Filename argument. I added that to mine but I think it will confuse users.
jwiede
  • Hero Points: 12
« Reply #2 on: August 21, 2017, 02:20:08 am »
Can we get the version with completion-enabled?  I know I'd rather have completion (and don't think I'll be confused by it).
  • Hero Points: 448
« Reply #3 on: August 21, 2017, 07:56:37 am »
How about we turn on completion once you type a path? The only downside is for the first part of a relative path. Once there is a slash or a drive letter, you will get completion.
  • Hero Points: 189
« Reply #4 on: August 21, 2017, 07:35:19 pm »
That would work ... you can always type ".\filename"
Does completion get turned off again if I deleted the leading ".\" ?
  • Hero Points: 448
« Reply #5 on: August 22, 2017, 12:53:57 pm »
No. Once you close the dialog and bring it back up then it starts with no completion.
jwiede
  • Hero Points: 12
« Reply #6 on: August 29, 2017, 01:47:39 am »
I'd certainly be fine with that (requires closing dialog to reset/disable completion).
JPorrkkahtc, that okay with you?
