Author Topic: Touch Bar Support ?  (Read 1013 times)
jmfrouin
Touch Bar Support ?
« on: August 10, 2017, 07:16:29 pm »
Hi,
Maybe a stupid question, but will you support touchbar under macbook pro after december 2016 models ?
It could be very useful under Slickedit.
But it's IMHO
Thanks
  • Hero Points: 436
Re: Touch Bar Support ?
« Reply #1 on: August 18, 2017, 05:19:37 pm »
I'll file a feature request for this one.
BTW, you probably already know that you can customize the touchbar to show the function keys per application.
- Go to Apple > System Preferences
- Select the Keyboard preference pane
- Click on the Shortcuts tab
- In the left sidebar, select the Function Keys option
- On the right-hand side click on the plus + button
- Select the SlickEditPro 2017 app
- Add the app
There are also several touchbar utilities out there that you can use to customize the touchbar for specific applications (they basically send keyboard shortcuts to the app).
jmfrouin
« Reply #2 on: August 19, 2017, 06:22:13 am »
Hi,
Before all, thanks to answer all question, even if they are not urgent like this one :)
I know, that it is possible to add SE as a shortcut in touchbar.
But yes I want to add some function (Debug, build, ...) directly to touch bar when Slickedit is open.
Thanks to open a feature request.
Best regards,
