Home
Help
Search
Login
Register
SlickEdit Community
Archived Beta Discussions
SlickEdit 201x Beta Discussions
SlickEdit 2017 v22 Beta Discussion
SlickEdit crashes when scrolling down
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: SlickEdit crashes when scrolling down (Read 3483 times)
bengle
Senior Community Member
Hero Points: 4
on:
August 10, 2017, 08:50:13 PM »
SlickEdit v22 Beta 1 crashes when I try to scroll down while editing one particular file. If need be, I could provide the file to you privately.
Logged
SlickEdit Team Member
Hero Points: 130
Re: SlickEdit crashes when scrolling down
Reply #1 on:
August 10, 2017, 08:54:46 PM »
Windows platform? And reproducible? You can submit file by opening a SlickEdit support case or just PM the file directly to me and I can investigate it.
Logged
bengle
Hero Points: 4
Reply #2 on:
August 10, 2017, 09:15:15 PM »
Very reproducible. It happens every time with this particular file. It is Windows 7 x64. How do I attach a file to a PM? If that's not possible, I'll open a case.
Logged
bengle
Hero Points: 4
Reply #3 on:
August 10, 2017, 09:18:29 PM »
I've just found another file with the same problem. Both are asm390 files.
Logged
bengle
Hero Points: 4
Reply #4 on:
August 11, 2017, 04:36:00 PM »
Opened case CAS-70161-TGP2.
Logged
Hero Points: 517
Reply #5 on:
August 11, 2017, 11:14:53 PM »
A bit late for beta2, but this will be fixed in beta3.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
