Author Topic: beta2 - can't load macro file  (Read 1061 times)
  • Hero Points: 119
« on: August 14, 2017, 06:12:50 pm »
Attached is my macros file. It loaded fine in beta1
When I try to load it, I get error:
robutils.e 41 51:Type mismatch for operator =
But from what I can tell, there is no type mismatch.
This line is:
old_search_options = save_old_search_options;
old_search_options is declared as:
search.e:
_str old_search_options = '';
save_old_search_options is declared as:
robutils.e
static _str save_old_search_options;
So why do I have this error?
Re: beta2 - can't load macro file
« Reply #1 on: August 14, 2017, 06:22:07 pm »
Added new prototypes for saving and restoring old search options in search.e, and the function is called save_old_search_options()/restore_old_search_options().  Conflicts with your static variable now.
