Author Topic: v22 Beta2 startup window size  (Read 1216 times)
Brandon
  • Hero Points: 5
« on: August 15, 2017, 02:02:37 pm »
Beta 2 doesnt seem to remember the size of the window when it was closed ... it always restarts at 1200x1024 (minus the title bar).
Any ideas?
  • Hero Points: 418
Re: v22 Beta2 startup window size
« Reply #1 on: August 15, 2017, 02:24:36 pm »
Make sure there isn't a hidden instance of slickedit running. Also, check if the date of vrestore.slk is changing when you exit.
Brandon
  • Hero Points: 5
« Reply #2 on: August 15, 2017, 04:18:46 pm »
There is not a hidden instance.
I seemed to be able to isolate this to an option in Languages->File Extension Manager->Encoding
I need ALL files to be UTF8, and if this is set to UTF8 then the problem seems to happen and the window always starts in the 1200x1024.
However, if I set to "UTF8, no signature" then the window seems to restore correctly.
  • Hero Points: 418
« Reply #3 on: August 15, 2017, 05:06:05 pm »
Please post your program information under help about.
Is it the main mdi window that is the wrong size or a floating window?
Brandon
  • Hero Points: 5
« Reply #4 on: August 15, 2017, 06:40:25 pm »
It's the main application window.   Attached a screenshot of the entire app window (again, 1200x1024 minus the titlebar, which seems to be the default size).   This is after setting the Languages/File Extension Manager/Encoding to "UTF8", and restarting SE.  Of course, the window was much larger than that when I exited.
Setting it back to "UTF8, no signature", and then adjusting window size will correctly restore it after exit/restart.
SlickEdit Pro 2017 (v22.0.0.2 64-bit)
Serial number: FE11862_BETA
License type: Beta License
License expiration: 2017-11-06 19:00:00
License file: C:\ProgramData\slickedit\22\slickedit.lic
Build Date: August 11, 2017
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 35% Load, 5831MB/16322MB Physical, 7594MB/32706MB Page File, 481MB/134217727MB Virtual
Screen Size: 2560 x 1600, 1200 x 1600, 1200 x 1600, 1920 x 1080
Project Type: (Other)
Language: .less (Less)
Encoding: Automatic
Installation Directory: C:\SlickEdit Pro 22.0.0 Beta2\ (non-removable drive,NTFS,174563MB free)
Configuration Directory: C:\SlickEdit Pro 22.0.0 Beta2\config\22.0.0\ (non-removable drive,NTFS,174563MB free)
  • Hero Points: 418
« Reply #5 on: August 16, 2017, 01:39:09 pm »
Reproduced
Thanks for figuring out which option is causing this.
  • Hero Points: 418
« Reply #6 on: August 16, 2017, 02:09:28 pm »
Fixed for beta 3
vrestore.slk needs to be written without a signature and this change had the side effect of putting a signature on vrestore.slk.
