Author Topic: Beta2: Display tab/space graphic options not honored on startup  (Read 925 times)
microcode
  • Hero Points: 9
V22 Beta 2
Windows 7 64-bit
In the "Special Characters" options window, the "Display tab graphic" and "Display space graphic" options don't seem to be honored when the app starts up.  The graphic characters are displayed even if the options are turned off.
This problem also exists in 21.0.3 so it's not new to V22.
To reproduce:
1. In the Special Characters window, turn off the "Display tab graphic" and "Display space graphic" options.  If one or both are already turned off, first turn them on, and then back off.
2. Click OK.
3. The tab/space graphic characters are not visible in a code window.
4. Close the application and re-open.
5. The tab/space graphic characters are visible in a code window, but in the Special Characters window the options are unchecked as expected.
microcode
  • Hero Points: 9
Re: Beta2: Display tab/space graphic options not honored on startup
« Reply #1 on: September 12, 2017, 07:21:02 pm »
This issue still exists in Beta3.
  • Hero Points: 446
« Reply #2 on: September 13, 2017, 12:05:03 am »
Fixed for next build. Thanks for posting
