Author Topic: B2 modified gutter after save  (Read 1808 times)
Stu
« on: August 21, 2017, 01:52:51 am »
forgive if not a bug, or a repeat, my current version is se2014... thought I'd try the 22beta2.
beautified a c buffer. line numbers gutter changed to red, saved... gutter stayed red. should revert back to unmodified colour. document tab colour did change back.
(this fresh config, nothing imported from se2014)
  • Hero Points: 448
Re: B2 modified gutter after save
« Reply #1 on: August 21, 2017, 02:11:38 am »
Turn on Tools>Options>File Options>Save>Reset modified lines
jwiede
  • Hero Points: 12
« Reply #2 on: August 29, 2017, 01:49:13 am »
Is there also a way for SCCS commit-or-moral-equivalent to auto-reset modified lines indications?
  • Hero Points: 448
« Reply #3 on: August 29, 2017, 01:36:36 pm »
No option for that yet
  • Hero Points: 139
« Reply #4 on: August 29, 2017, 08:12:25 pm »
Does this modify the file (cause an auto reload)?
jwiede
  • Hero Points: 12
« Reply #5 on: September 01, 2017, 07:14:49 pm »
Not reliably.  It might register when I tell SCCS to revert file to write-protected, but often I'll commit and immediately reopen the same file, and in that case I'm not sure there's any obvious change visible.
