Author Topic: VSdiff - cmdline  (Read 1083 times)
  • Hero Points: 188
VSdiff - cmdline
« on: August 22, 2017, 09:06:13 pm »
I ran vsdiff from the cmdline to compare two folders.
I changed the diff options and hit refresh
It prompted "Refresh modified files only?"
I click "No", then I get the error below.
Slick-C Error
file=diffmf.ex offset=134
OK
I hit refresh again, and got a slightly different error.
Slick-C Error
Control ctlleft referenced but does not exist
OK
Hitting "YES" instead of no, gets me:
Slick-C Error
Invalid argument
file=diffmf.ex offset=23720
OK
And the diff window is now blank - showing no files at all.
  • Hero Points: 137
Re: VSdiff - cmdline
« Reply #1 on: August 23, 2017, 02:08:49 pm »
I'll take a look at this.
  • Hero Points: 137
« Reply #2 on: August 23, 2017, 04:49:18 pm »
I can't reproduce this one either.
Is it the same basic scenario as from inside diff?  If so, the same questions apply.
Also, did you enter this from the dialog, or put it all on the command line?
