Author Topic: VSDiff cmdline - options  (Read 930 times)
  • Hero Points: 179
« on: August 22, 2017, 09:11:05 pm »
I run Vsdiff from the cmdline, click "Options" and I get this error
SlickEdit Pro
Failed to save configuration to 'C:\users\joe\Documents\SlickEdit\22.0.0\vslick.sta'.
Access denied
OK
SlickEdit Pro
Unable to save the configuration
Do you want to correct the problem and try again?
If you can't correct the problem, your configuration changes will be lost.
&Yes   &No
  • Hero Points: 133
Re: VSDiff cmdline - options
« Reply #1 on: August 23, 2017, 02:07:12 pm »
I'll take a look at this.
  • Hero Points: 133
« Reply #2 on: August 23, 2017, 04:18:33 pm »
Did this happen as soon as you clicked on the "Options" tab?
I assume you had an editor running with the same configuration directory?
I wasn't able to reproduce this one.
  • Hero Points: 179
« Reply #3 on: August 23, 2017, 05:31:24 pm »
In Slick I have Tools > Options > Application Options > Exit -> SaveConfig == SaveConfigImmediately.
When I change this to save on exit, this problem goes away.
When I hit options, the Diffoptions dialog appears and the error dialog immediately appears on top of it.
