Author Topic: B2: Search Backward option is sticky with Brief emulation  (Read 1210 times)
microcode
  • Hero Points: 9
« on: August 25, 2017, 06:53:32 pm »
V22 Beta 2
Windows 7 64-bit
Brief emulation mode
Full-size search dialog used (not mini)
After searching backwards (Alt-F5) for some string, and then hitting F5 to search forward, the "Search Backward" option in the search dialog remains on unexpectedly.  But the opposite works as expected (i.e. after searching forward, hitting Alt-F5 seems to always turn on the "Search Backward" option as expected).
In v21.0.3, hitting F5 always seemed to turn off the "Search Backward" option and Alt-F5 would turn it on.
« Last Edit: August 25, 2017, 06:55:03 pm by microcode »
Re: B2: Search Backward option is sticky with Brief emulation
« Reply #1 on: August 25, 2017, 07:11:47 pm »
Thanks for the report.  Reproduced, will fix that for Brief emulation in the next beta drop.
