Home
Help
Search
Login
Register
SlickEdit Community
Archived Read Only Forums
SlickEdit 2017 v22 Beta Discussion
Slick hang in perl RE search
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Slick hang in perl RE search (Read 1263 times)
Senior Community Member
Hero Points: 190
Text
on:
August 29, 2017, 11:58:29 pm »
In the regex tool I was playing with a regex to match a path.
Open the attached TXT file.
In Find, do a Perl RE search in that file with this pattern
([a-zA-Z]
?([\\/]*[^\r\n<>:"\\/|?*]+)+[\\/]?\(([0-9]+)\):
And slick hangs.
Logged
SlickEdit Team Member
Hero Points: 453
Re: Slick hang in perl RE search
Reply #1 on:
August 31, 2017, 02:39:52 pm »
Reproduced. Thanks for the small sample
Logged
Hero Points: 453
Reply #2 on:
August 31, 2017, 03:16:12 pm »
It turns out that this is a really slow regex. If you let it run for a very long time, it will finish. On my machine (pretty fast windows machine), it takes about 62 seconds to finish.
If I hold down Ctrl+Alt+Shift+F2, the search is cancelled.
Logged
Hero Points: 190
Text
Reply #3 on:
August 31, 2017, 04:35:33 pm »
Thanks.
Can you give any advice on why it is so slow and how to improve it?
I tried a number of things, but it seemed that as I made changes it would go from being quick to being *really* slow - not a lot of in between.
I tried replacing "+" with "+?" and "++". Especially with ++ I expected it to make a perf difference.
Logged
Hero Points: 453
Reply #4 on:
August 31, 2017, 10:13:39 pm »
Without spending too much time on it I tried this:
([a-zA-Z]
?+([\\/]*+[^\r\n<>:"\\/|?*]++)+:
I got rid of most of the backtracking. I'm not sure what you were trying to accomplish with the regex stuff after what I used.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
