Author Topic: Search Results: Filter doesn't work.  (Read 1461 times)
  • Hero Points: 184
« on: September 05, 2017, 07:49:31 pm »
Search results Filter doesn't seem to work.
I have a result with 336 matches over 35 files.
I filter for "Error:", and DeleteLine selected.
The message window says "35 removed lines".
All of the matches with "Error:" are still present.
It does remove the 35 "File C:\...." lines though
If I repeat the same Filter, it says "No matching lines found".
Hmm..KeepLine and DeleteLine seem to give the same results.
Re: Search Results: Filter doesn't work.
« Reply #1 on: September 05, 2017, 08:08:23 pm »
Thanks for the report.  Tested and got the same thing, there do appear to be issues with Filter Search Results.  Will work on a fix for future beta drop.
