Author Topic: Undo doesn't work after diff  (Read 22546 times)
  • Hero Points: 141
Re: Undo doesn't work after diff
« Reply #90 on: February 12, 2018, 02:37:31 pm »
These are all nice features.  I can't promise how many I can do for 2018.
  • Hero Points: 141
« Reply #91 on: October 15, 2018, 03:16:20 pm »
This happens in V21.0.3 as well as in beta 3.
Make a change to a buffer, right click on a file tab and select diff.  After the diff window opens, close it and do Ctrl-Z undo.  Slick moves the cursor to the bottom of the buffer and says "cursor movement undone".  Do ctrl-Z again and slick says "nothing to undo".
This feature has been added for 23.0.  I think it's in Beta 6, but it's definitely in RC 1.
