Author Topic: Modifying read only files, 2 questions and 4 bugs  (Read 958 times)
  • Hero Points: 185
« on: September 06, 2017, 05:56:31 pm »
When a file is read-only, and I attempt to modify it I get: (Protect Read Only Mode is ON)
    SlickEdit Pro
    This command is not allowed in read only mode
    OK CANCEL "Change RW"
#1: What is the difference between OK and CANCEL here?
#2: if I click "Change RW", I get a second dialog
    C:\blah\blah\blah.c is read only
    Do you wish to:
        o checkout
        o get latest
        o make writable
        o save as new
2.1 Can I suppress this second dialog and keep Protect Read Only Mode ON?
2.2 Why is "Save as new" disabled?
NOTE: This is a file that is not part of a project or workspace. Just any random read-only file.
BUG #1: If I turn off version control for the current project, then do as above and select "Checkout", I get this error:
    SlickEdit Pro
    Command 'lock' not available
    OK
BUG #2: Repro bug #1 by typing a letter into a read-only file.
    1. That is, load a readonly file
    2. type a letter
    3. Click on the ChangeRW button
    4. Select "Checkout" and click OK
    5. Click OK on "Command Lock Not Available"
    And the letter is inserted into the read-only file.
    This violates my "Protect Read Only Mode" setting
BUG #3: Follow on to #2: Steps
    1. Repro bug #2
    2. In the same file type another letter
    Now I get this dialog
        Another Application has modified the following file:
            C:\blah\blah\blah.c
            Do you wish to reload it?
            yes/all/no/diff
        [X] Always reload files without prompting.
    But of course, nobody else modified the buffer.
    You don't even need to switch away from Slick for this one.
Bug #4: That checkbox is checked, so why is it asking me then?
    Shouldn't that checkbox being checked suppress this particular dialog?
  • Hero Points: 137
Re: Modifying read only files, 2 questions and 4 bugs
« Reply #1 on: September 06, 2017, 05:58:05 pm »
I will look into these.
  • Hero Points: 185
« Reply #2 on: September 06, 2017, 06:18:10 pm »
BUG #5:
    2. type a letter
    4. Select "Make File Writable" and click OK
    And the letter is NOT inserted into the now writable file.
    By contrast, Bug #2: The change is made and should NOT be.
BUG #6: Repro Bug #1:
    1. Load a readonly file
    2. type a letter
    6. Save the file (which is still read-only)
    7. Get prompted "File is read only, Do You Wish To...
        Click the MakeFileWritable button
    8. The file is changed to RW, but it is NOT saved.
BUG #7
    0. Load a project with GIT version control
    2. type a letter
    5. Get prompted for "Command Lock Not Available"
It shouldn't do that .... either "Checkout" should be disabled, or it shouldn't always give an error.
