Author Topic: B3: ES6 class methods defs not shown  (Read 1187 times)
PiezonTM
  • Hero Points: 7
« on: September 07, 2017, 06:29:08 pm »
Depending on a single line of code that I isolated will prevent the outer class methods from being shown in the "Defs" window.
With the attached "es6sample.js" file you will NOT see OUTER_METHOD or OUTER_METHOD2 in the listing--or any other outer method following the one line of code.  But you'll see the method outer methods private functions. (see defsWithProblem.png)
Now, comment out line 28
someVar: -1
The "Defs" windows WILL show the OUTER_METHOD or OUTER_METHOD2 in the listing. (see defsWithoutProblem.png)
SlickEdit Pro 2017 (v22.0.0.3 64-bit)
Serial number: FE17393_BETA
License type: Beta License
License expiration: 2017-11-06 19:00:00
License file: /opt/slickedit-pro2017beta3/bin/slickedit.lic
Build Date: September 04, 2017
Emulation: CUA
OS: Linux
OS Version: Ubuntu 16.04.2 LTS
Kernel Level: 4.10.0-32-generic
Build Version: #36~16.04.1-Ubuntu SMP Wed Aug 9 09:19:02 UTC 2017
Memory: 37% Load, 9149MB/24321MB Virtual
Shell Information: /opt/slickedit-pro2017beta3/bin/secsh -i
Language: .js (JavaScript)
Encoding: Automatic
Installation Directory: /opt/slickedit-pro2017beta3/
Configuration Directory: /home/tmoore/.slickedit/22.0.0/
Migrated from: /home/tmoore/.slickedit/21.0.3/
Spill File: /tmp/$slk.tmoore.27145
  • Hero Points: 121
Re: B3: ES6 class methods defs not shown
« Reply #1 on: September 07, 2017, 07:24:07 pm »
Reproduced, taking a look at it.  Thanks for the report.
  • Hero Points: 121
« Reply #2 on: September 07, 2017, 08:02:48 pm »
This will be fixed in the next drop.
