Author Topic: Beta3: Error when opening Maven workspace (pom.xml) where the name has spaces  (Read 783 times)
texasaggie97
  • Hero Points: 4
When opening "Other Workspace" and choosing maven, I get this error if the name in the pom.xml has spaces in it:
SlickEdit Pro
Unsupported extension for workspace filename.  Can't open C:\Users\msilva\Documents\GitHub\ghprb-plugin\GitHub
OK
In particular the name is <name>GitHub Pull Request Builder</name>.
If I remove the spaces I do not get the error.
If I hit "OK", it still creates and opens a workspace. I wasn't sure if the workspace generated after the error would be complete or correct so I removed the spaces and used that generated workspace instead.
I also reproduced this error with v21.
Thanks for the report.  I reproduced the issue and will work get a fix in for for next beta drop.
