Author Topic: Regex Evaluator: F7/F8  (Read 761 times)
  • Hero Points: 182
« on: September 11, 2017, 11:20:22 pm »
Usually I find that F7/F8 do not work in the regex evaluator.
Typically when I hit F7, Slick starts a project build!
If you move the control focus to the expression control, then F7 works properly.
Having F7 start a build is pretty surprising from the regex tool - it probably shouldn't do that.
  • Hero Points: 417
Re: Regex Evaluator: F7/F8
« Reply #1 on: September 12, 2017, 02:19:37 pm »
Fixed for next build
