Author Topic: DZ && Token Mapping  (Read 877 times)
  • Hero Points: 188
DZ && Token Mapping
« on: September 13, 2017, 07:06:09 pm »
#1: You cannot change Diff options while the side-by-side diff window is open.
#2: Once #1 is fixed: During a side-by-side right click on a line with differences and in the context menu there should be an "Add difference to Token Mapping"
Selecting that would open the TokenMapping "Add Item" with left and right prepopulated with the left and right lines of the files.
Exactly what text to add? Several possibilities:
1 The entire lines.
2 Just the  range of text from the left and right from the left most diff to the right most diff.
3 Same as 2, plus a few extra characters fudge factor.
  • Hero Points: 447
Re: DZ && Token Mapping
« Reply #1 on: September 13, 2017, 07:15:16 pm »
Good suggestions.  Not easy to implement.  Will file a feature request for a future iteration.
